Created by Dan.Louchbaum
Rotate Vertical Gauge Value to also be Vertical
When using a Vertical Gauge the value at the top takes up a lot of space because the gauge is a vertical, yet the value is horizontal. The horizontal text is typically wider than the gauge itself. This is not a big deal for 1 gauge, but when we convert it to a collection to pull multiple gauge together we want to see them side by side. The collector spaces them out taking up too much real estate. If we had an option to ROTATE the value on the vertical gauge to also be Vertical we could keep all gauges packed much more tightly together. The ask is to provide an additional field in the "visibility" section of the gauge to allow rotation of the Value. Optionally to rotate the units/label with it. Workaround from OSI was to use a horizontal gauge instead because the text is horizontal but most of my users understand these charts better in vertical gauge form. See image of the wasted space in my collection.
