Categories Events (EF)
EF integration into symbols
Like many customers, we make heavy use of event frames. It would be great if Vision symbols could make better use of EFs. For example: 1) Allow configuration of multi-state symbols based on whether an EF is active at a particular time. For example, a downtime EF is active on a piece of equipment, so you want the asset to turn red. Otherwise, I believe you need to recreate the EF logic in either a second analysis or create a Vision calculation. These options are not necessarily available if the EF comes from a batch interface. 2) Allow bar charts to count #'s of EFs using dynamic search criteria. For example, you have a group of reactors and want to count the number of unit procedures run on each reactor over the past month. Or you want to count the number of alarms on each reactor. This would allow customers to use # of events as performance indicators and identify outliers.
