126 VOTE
Categories Events (EF)
Events table: search for event frames by asset root path (including all descendants)
It would be useful to be able to configure the events table symbol in PI Vision to search for all event frames that reference elements below a certain root. This would allow you to see all EFs related to a certain branch of your AF hierarchy very quickly.
  • Oerjan Sikveland
    May 13, 2024
    IIn PI Vision we have plant displays showing overall status of plants, detailed displays on subsystems and even more detailed displays on component levels. All of these have event tables.
    On plant level we want to see active events for the entire plant, on subsystem active events for entire subsystem and on component levels we want to see all events that have been active in the timebar duration independent of status. In all cases we want filter (within the search criteria) by the hierarchy, showing data from the selected level and all levels below.
    Our problem today is that the nearest option to get what we want is to filter by “Assets on Display”, this works fine for component level and most subsystems. However, we do add attributes to displays which are not that relevant to meet the criteria “Assets on Display”. On plant level we miss out relevant events based on that we can’t have alle assets on a display.
    One of the main selling points for the PI System is the functionality around the AF hierarchy. I find it strange that a hierarchy filter like this is not part of the PI Vision search criteria to utilise the strength of the AF hierarchy.
  • Angus Lay
    Sep 11, 2023
    Had to split my single asset into a hierarchy due to performance issues within Pi due to the number of analyses running, causing Pi to run slow/stall for minutes at a time. Now that I have done that, the only way to see the events at the child level to the parent is to view all, which brings through all the events for all the machines created under that Asset template. Seriously frustrating that i cannot use the parent ID to filter, and still see the event frames that reside under that parent ID.
  • taterhead247
    This is a necessity in my opinion.
    Yes this would allow you to see all EFs related the assets on screen.
  • Carlos Garcia
    Please add more flexibility to the filters: major than /minor than in timestamps, and filtering with contain / does not contain / starts with, etc
  • Hobbe
    The problem is also in the Collections in PIVision! When you configures the collections you lose the Event Frames.
  • Hobbe
    I have discribed the problem in this post! https://pisquare.osisoft.com/thread/40990-event-frame-search-not-working-with-collections-or-dynamic-search-criteria
    Without this feature the asset swapping capability in vision basically becomes very hindered. If I swap root assets everything on the screen will change except event tables. They need to be manually changed any time the root asset is changed.
    This option is necessary. The Event Frame tables should work along with collections.
  • rfesler
    this would be an amazing improvement for our refinery. we have wayyy too many plants for one event frame table to work and do not want to create multiple displays or tables. context switching is a must along with asset root path.
  • +26
