399 VOTE
Status Completed
Categories Events (EF)
Events Table: Show attribute values
Be able to compare attributes from multiple similar events against each other in the events table symbol. User Story: As a process engineer, Lalit wants to compare attributes from similar events to one another in a table and sort by the columns of the table SO THAT he can use the attribute values to compare the events to one another.
    PI Vision 2021 introduces new capabilities that allow users to add event attributes and related asset attributes to the Events Table. See an overview of new PI Vision 2021 capabilities on our YouTube learning channel: https://youtu.be/LomuqXKEH7w For additional information on PI Vision 2021, please see the release announcement here: https://customers.osisoft.com/s/knowledgearticle?knowledgeArticleUrl=000037703
    please add feature, thanks
    Us too! Showing the attributes of the events would allow user to quickly see where deviations occurs for a particular event in a table form without looking into the time-series charts.
    a million times yes!! :)
  • Jason Gogal
    YES please.
    Customer would like to have the option to display Event Frame attributes in the Events Table symbol
  • Jason Gogal
    Yes and yes please.
  • Carlos Sola
    It would be nice to add other EF Attributes to the table as we do with PIDataLink. I can't believe it is not implemented yet, it would give more value to the tool.
    Yes, it would be a good use. OSISoft is already has this feature on Event frame search using PI System Explorer. why not the same with PIVision?
    Please Add..
    This is a needed feature, especially since you are pushing a move from PI Batch to Event Frames. Event Frame visualization is not as capable as PI Batch visualization.
    Please add capability to add arbitrary EF attribute to Events Table for visualization. So far the customer has to include values of attributes to the name of EF to show it.
  • Nathan Skitt
    PI Vision already sees these values when you click an event in the events panel, so we know it has access to the information. This would be a very valuable feature for our customers.
    +Add wrap for HUGE text
    This could be a solution for customized EventFrame Analysis Displays. A link, which is built as an event frame attribute could be displayed in the Event Table and used for further digging.
    There is no doubt that is Highly required. The possibility to compare events with the same type is so trivial that I thought it was an existing feature. Please add this feature ASAP.
    Without EF attributes in the comparison table in Vision, it's of little value to us. Having a few simple attributes exposed would make it incredibly useful!
  • Jürgen Schmidt
    We have the same request from one of our customers. They are monitoring their filling line and want to Dashboard which line is currently busy with which order and how much already has been filled. With additional attributes in the Event Table, they could easily show that with just one query.
  • CharlesCopeland
    Allow for display of EF Template specific attributes on an Events Table when a specific template is selected. Much like how specific attribute data can be pulled through DataLink, but only when a specific template is selected in the Explore criteria.
  • JanWortmann
    We use the event table to monitor off-spec events triggered by laboratory values. It would be very helpful to be able to compare the value with the thresholds.
    YES please! We are reporting our process exit cycle time. One thing we need to grab is the Batch ID at the end of the event frame so we made a EF attribute to store the info. It would be super helpful if the information could be displayed as one of the columns.
  • Load older comments
  • +299
