Categories Ad Hoc Analysis
Created by Ananya Bhakat
Multiple floating Ad-Hoc windows
- User opens a main PI Vision display window, where there are multiple PI tags/items in view either in trends or value displays etc. - Now, once user double-clicks any of the PI items in the display, it should open a separate floating trend page (not covering the original display window) - And user should be able to further select another PI item(s) in the main window still (holding down ctrl key) and drag them into the same floating window. - Or, from main window, simply double-click another item, and that should open into a 2nd separate floating window. - They should be able to open multiple such floating windows (or adding more items into any of such existing floating windows as needed from items in main display window). -And, these floating windows, should be able to take inputs (more items to be added) from other displays (meaning, users should be able to switch main displays to different displays, and they should still be able to add items to these existing floating Ad-HOC windows from the new main displays).
  • Brian brian.e.roberts
    Feb 22, 2024
    Will second Ananya's comment that the key is getting better interaction from "active" display to an Ad-hoc display so you can add to an add-hoc . Natural action is to drag or copy value onto an ad-hoc trend display. making it so it is just copy/paste of the tag or drag of the tag speeds analysis instead of realizing you need the tag on your ad-hoc. Now you have to close-select tag-add-reopen. Or you end up creating a throwaway pi vision display. and search for the pi tag to add there. task is not hard but this extra step(s) gets repeated everyday multiple times.
  • Julian Siano
    Dec 14, 2022
    This is a great feature. There are sites that managed to write VBA code to do this in Processbook, and having this feature in PIVision would really help with user adoption.
  • Ananya Bhakat
    The key ask here is to be able to have a live interaction between the main display and the floating Ad-hoc windows. Instead of, as of right now, having to close the ad hoc workspace, then pick items from main window to add to a single Ad-Hoc window.
    1、曲线弹窗这个功能非常重要,现在一调曲线就看不到画面,不利于操作,不人性化,建议增加曲线弹窗功能; 2、拉曲线不方便,最好能够实现直接拖住测点就可将测点拉至曲线弹窗。
