Status Completed
Created on Aug 16, 2022
Allow PI Adapter for MQTT (Generic) to process non-json payloads
Some MQTT devices do not send json payloads; for example, some devices send a single value as the payload for a specific topic. It would be beneficial for the adapter to be able to handle this rather than to convert these payloads into json before they get to the adapter.
    Aug 16, 2022
    We would like to know more about the frequency in which our customers come across this scenario. Please share your use cases in the comments section.
  • Admin
    Jiyeon Hwang
    Apr 21, 2026
    Thank you for your feedback. This capability is now available with the latest release of AVEVA Adapter for MQTT (1.4.0.455).
    Nov 11, 2024
    My sensors publish its data as "raw-value" to a topic.
    So e.g temperature is just a float 36.1 and not {"value":"36.1"}.
    Thus I'm not able to use the adapter for this sensor, because the adapter requires data as JSON.
  • Zahab Nabeel
    Oct 8, 2024
    Spent 6 hours on a project where we needed data from a solar panel that was accessed through MQTT Adapter in the form of numerical values. We succeeded easily with integration with AVEVA Historian using the MQTT however kept failing with PI Adapter due to inability to find the items. After so much efforts and time spent we came across this enhancement request and figured we do not even support it. I hope it would be added soon just as it is already available and easily configurable with AVEVA Historian.
    Aug 16, 2022
    In this use case the PI Adapter was proposed but devices are already in place and publishing raw data payloads to the MQTT broker so it is not feasible to change the data to JSON or Sparkplug. Workarounds to convert the data to Sparkplug increases the effort needs, and the costs involved.
