Status In development
Created by Hans-Otto Weinhold
Created on Jul 21, 2023
Prevent PI Adapter for OPC UA from modifying/override stream overrides and metadata upon restart
Problem: I have configured PI Adapter for OPC UA to collect data from an OPC UA Server. Since UoMs are not assigned properly, I created stream overrides in AVEVA Data Hub to assign the proper UoM to the particular stream. I also associated stream metadata to translate the naming convention of the stream name to reflect "human readable" metadata. This data all remains available until I restart the PI Adapter. Once the PI Adapter gets restarted, the stream overrides are reset and also the metadata seem to be lost as well. So I need to re-run the script for assigning the proper UoMs each time which is a bit annoying.
Solution: prevent PI Adapter framework to overwrite stream configuration when it initializes. It should be a configurable option.
  • Admin
    Jiyeon Hwang
    Mar 31, 2025
    Thank you for your feedback and comments. As Sahil mentioned in his comment, there is a similar request for the AVEVA Adapter for OPC UA that is related. With the next release of the OPC UA Adapter (with the updated version of the Adapter Framework that addresses this enhancement), you will be able to configure the adapter to include or exclude the following properties: Description, Minimum, Maximum, UoM, Interpolation. I will update the status of this feedback once we release the next adapter version.
  • Lionel Gergaud
    Sep 11, 2024
    You can extend to DESCDRIPTOR, ZERO/SPAN too.
    Because some 3rd party OPC SERVER are'nt modifiable for these attributes and it's a big problem !
  • sahilp
    Nov 23, 2023
    The idea seems to be focused on ADH. I would add the explicit requirement that the UOM should not be overwritten for PI Server also.
    Similar ideas for the descriptions here
    https://pisystem.feedback.aveva.com/ideas/PIADAPTERS-I-36
    https://pisystem.feedback.aveva.com/ideas/PICNCTRS-I-224
