Status Completed
Product PI Connectors
Do not synchronize description from OPC UA server into PI Tag
There are situations when customer prefers to use “description” in PI Tag attribute that is independent from item “description” provided by OPC UA Server.   Currently, during each synchronization, the OPC UA Connector synchronizes descriptor from OPC UA to PI Tag and overwrites desired “Descriptor” attribute provided by customer.  Although the solution would be to have desired description already on the OPC UA Server, in some situations (OPC Server managed by 3rd party) it is not possible. It would be good to have configurable parameter in OPC UA Connector, which disables synchronization of item description from OPC UA Server to PI tag.
    Jan 13, 2026
    This was completed in the 2.1.0.7 release of PI Connector for OPC UA. There are now settings in Transformational rules that allow users to disable unwanted synchronization from the source OPC UA server, preventing Descriptor, Eng Units & Zero and Span being overwritten on the PI Tag attributes. See the documentation: https://docs.aveva.com/bundle/pi-connector-for-opc-ua-gen-2/page/1009886.html
  • David Hooper
    Jan 14, 2026
    Thanks!
  • Kaye Ursell
    Jan 14, 2026
    The development took a very long time, but it is solving a lot of issues that we previously had. thank you
  • sahilp
    Mar 12, 2025
    “In development” since at least 07 May 2024…
  • Lionel Gergaud
    Sep 11, 2024
    Hello,
    It's the same problem with the OPC UA adapter.
    And we have the same problem with 3rd party OPC server, for the attribute Eng Unit and zero/SPAN
  • Kaye Ursell
    Jul 29, 2024
    Can you please provide an update, this request was submitted 2 years ago, also as per below will this also be implemented in the Adapter.
  • sahilp
    May 7, 2024
    Hi,
    The item is now marked "In development". Can someone from AVEVA please provide an expected completion date?
    Thanks,
  • sahilp
    Nov 23, 2023
    The same idea needs to be implemented in the adapter, or at the time of migrating all the connector users will be back to square one.
    https://pisystem.feedback.aveva.com/ideas/PIADAPTERS-I-36
    Mar 28, 2023
    Please fix this. You can't expect SCADA descriptions to always be useful for the end users. I understand the power of the OPC UA server being able to hold all this meta data. But PI being a separate client that extracts the data should have the ability to choose whether or not it wants any of that information.
  • Julian Shearing
    We have a slightly different use case. It's fine to synchronise but we need the ability to turn it off after the connector has built the initial setup. Our problem is when buying off the shelf equipment we have no control over how the vendors present the data. The built in OPC server to the equipment may not be configured in a way that is user friendly or even complete. We could of course resolve this by requesting customising of the source system but that leads to considerable increases in complexity and cost and some vendors are not prepared to entertain doing it! Therefore the ability to synchronise the initial build and then turn off the auto update and complete the build in PI would be really helpfull
    Another use case is you connect to a Control System via OPC UA The description in the control system is too generic e.g. the Control System has a connection to anther system and just has all the tags with the same description. Therefore you would want to have different description in PI.
    This is very critical functionality for many customers. OPC UA is the preferred way of connecting control system in coming days and industry 4.0 and other program like Open Process Automation have very high dependency with OPC UA . This is must to have idea where we need OSIsoft Support to enable functionality on choosing not to have auto update for Description and Eng-Unit.
    This behaviour happens also with "step" attribute on the PI Adapter for OPC UA. In particulart this happens every time Adapter is restarted or history recovery is performed. The workaround is to have desired "description" already on the OPC UA server but in some situations (OPC UA server managed by 3rd party) this is not possible. It would be good to have configurable parameter in OPC UA Adapter and Connector, which disables synchronization of "description" and "step" attributes from OPC UA server to PI tag.
