Created by Kelsey Bobeck
Created on Jan 1, 2026
Improve Search and Results in Forum
The search in the forum is borderline unusable and would benefit greatly from improvement. Currently, the results are irrelevant*, common search methods don't work**, and hitting enter after the initial search results in an error.
*In the attached example, my search was '"powershell" min max' and the top results talk about everything but PowerShell: PI Web API, Event Frames, AFSDK, VBA, OLEDB, and so on.
**Quoting PowerShell should have ensured it showed up in the the results (note that removing quotes returned the same results).
  • Kenneth Barber
    Aug 19, 2026
    It's a shame that the search is so bad because the search that OSIsoft had on its websites worked fine, so, in theory, AVEVA would just need to copy that search algorithm. The current search is the reason why I don't use the forums anymore.
