Created by Haavard
Analysis Preview Results - Remove Table and Graph
When using the preview analysis function an an analysis with many variables the preview graph and table struggles to keep up, and uses a long time to update. When there are many variables, these are also quite useless. It would therefore be an improvement if these could be made optional so that the preview output could be taken directly to a .csv file.
    Also, the user should select which attributes he wishes to trend or view in the table. The first x columns tend to be the least useful ones as the important results are typically the last values written by the analysis.
  • Brent Bregenzer
    I agree with Chris Lonsberry and have received this same feedback from customers. The ability to select which variables and/or inputs you want in the graph/table would be most useful. Having the ability to turn off completely to get just the stats would also be nice so that if the stats suggest the triggering is too frequent, one could adjust the trigger schedule and then preview with table/graph.
