Created by Kenneth Barber
When converting an element to a template, suggest substitution parameters based on the ConfigString
Currently, if the ConfigString of an attribute looks like this: \\ServerName\TagName;UOM=uom then if you right-click on the element and go to Convert → Convert To Template, the Substituted column will suggest this: \\ServerName\%Element%.%Attribute%.%ID%;UOM=uom regardless of whether TagName is in the format %Element%.%Attribute%.%ID%. Instead, consider suggesting substitution parameters based on the ConfigString. For example, if %Server% evaluates to "ServerName" and %Attribute% evaluates to "TagName", then make the following suggestion: \\%Server%\%Attribute%;UOM=uom
    The current behavior with element template with PI Point attributes is to have a default substitution parameter as you described regardless of whether you're creating the attribute from scratch or if you change an element to a template. Your suggestion of changing this default only when changing an element to a template assumes that the PI Point name can be replaced with a %attribute% substitution parameter. We have no data to support whether this is an improvement or not and it would be a change in behavior only for a specific use case. The default %element%.%attribute% maybe suitable if you have an element name for your asset and an attribute name for your measurement. So for example, if you have an element=pump and an attribute=flow, the current default would result in a PI Point name = pump.flow, if you were to create the PI Point from the element template. We currently do not have enough data to support a change in this behavior.
    • Kenneth Barber
      Reply
      Of course, OSIsoft will have to decide what to do when there are conflicts. For example, if the tag name is ABC, the element name is AB, and the attribute name is BC, do we use A%Attribute%, %Element%C, or nothing? Also, I wouldn't expect such a feature to consider substitution parameters involving ancestors, such as %..\..\Element%, since there would be too many cases to check and these substitution parameters are uncommonly used anyways.
