Product PI Integrators
Created on Aug 16, 2022
Have the Column Headers show up regardless whether this is the first of second file of an export data file?
Have the PI Integrator for Business Analytics always create Column Headers regardless if it appending to the same file or a different file, and ID to reset to 1. Currently, "Append Timestamp" is unchecked and upon the program removing the file from the original export location, sometimes the column headers will not show up and the ID will not reset as the Integrator believes that it is appending data when the first file that is gone. The First file will always contain the Column Headers and ID will start at 1. Please let all subsequent file Column Headers and ID will start at 1.
    Aug 16, 2022
    Thanks for the feedback! Are you using the File target or the ADLS gen 1 target?
    Aug 16, 2022
    File Target
  • PowerPI
    Aug 16, 2022
    I don't quite understand why this is not the default. If "Include Headers" is checked and the file doesn't exist and needs to be created, I would expect that the headers would be included. I have many views that run each evening and collect data for the month to date using the file target. At the end of the month, the file gets archived and a new file is created. Many of my clients have automatic processes in place that import the data and including the headers is preferred. Please modify this process. Thank you.
