Status Completed
Categories Symbols
Created by Ananya Bhakat
Created on Aug 18, 2022
Trend: Scale grouping
On the trend symbol, we would like to select specific tags to share a single scale which auto-updates, while the other tags use independent scales. All on the same trend. For example on the same trend, • PICXXXXXX.PV & PICXXXXXX.SV need to share a single scale which auto-updates using the range of their plotted values. • PICXXXXXX.MV & ZTPXXXXXX.PV need to share a single scale which auto-updates using the range of their plotted values. • Tag PICXXXXXX.MODE needs to be on its own axis scale The solution provided for the idea titled "Trend: Shared dynamic scales" creates a single scale but it does not auto-update using the range of plotted values.
    Dec 15, 2025
    This item has been completed as part of the AVEVA PI Vision 2025 release. Watch an overview of the new features here.
    For additional information on AVEVA PI Vision 2025, please see the release notes here.
    Nov 6, 2025
    Yes looking forward for this update. This will significantly increase efficiency of using PI Vision, since this would enable to have Controller PV and SP trended together on one dynamic scale with Output on the same trend but different scale.
  • Ananya Bhakat
    Feb 7, 2025
    @Admin: Please find my answers below:
    1. Our Chemicals users would like to have the ability to create one Control Valve view with all five trends scaled for each controller (as mentioned in idea description). Then they would build out a system page of all the controllers in that system for monitoring purposes. A broad system view of all the system controllers is very important for the I&C engineer performing their daily Proactive Technical Monitoring (PTM). Having the option to group scale as described would help them acheive this.
    2. It would be good to have this feature as additional option in the existing Trend symbol.
    3. Our operators and engineers at the Chemicals and Downstream sites.
  • Athanasios Kitsios
    Feb 4, 2025
    More advanced functionality can include a dual axis on the trends with the ability to scale both of them differently.
    Mar 19, 2024
    This is a basic function in Excel and I'm not sure why it isn't included in PI Vision
  • dmustain
    May 12, 2023
    I want to point out that a request from Shell is that one lower range could be fixed while the multiple 'scale-with' ranges are applied. For example, the lower range set to 0 while other groups are scaled-with each other and the higher range is automatically adjusted based on the output value.
    I'll also ask others to share more details of the specific requirements.
  • Bo_H
    Aug 18, 2022
    Why doesn't this functionality already exist! Would allow for more info on one trend view. This is a great addition to the tool.
    Aug 18, 2022
    This feature would greatly enhance the functionality of PiVision for process control applications, where its is often very helpful to have Controller PV and SP trended together on one dynamic scale with Output on the same trend but different scale.
    Aug 18, 2022
    This would be very helpful!
    Aug 18, 2022
    This idea is definitely something I would use to allow me to use divergent unit types on the same graphs. Today I do not do that using multiple plots where information may be better shared, sometimes, on one graph.
    Aug 18, 2022
    Really want this.
  • dmustain
    Aug 18, 2022
    This is a spectacular idea. It would make PI Vision so much better
    Aug 18, 2022
    Lack of this feature is stopping me from using PI Vision. I want to scale the process value and setpoint on the same scale and the output on a different scale (%), while having all 3 on the same trend.
    Aug 18, 2022
    This makes trends more user friendly.
  • inform2prabhat
    Aug 18, 2022
    Hope this will be taken care soon. Very important !
  • Brian brian.e.roberts
    Aug 18, 2022
    This would be a good addition for PI Vision. We want users to be able to start analyzing data and not have to tediously setup manual axis that don't update. We have a heritage plant data viewer that allows autoscaling of 2 variables on the same axis while setting a third variable to its own axis or autoscale itself on the same trend similar to those attached. One feature not seen in many auto scaling setups is the ability to fix MIN or a max ....ie. I would like to fix my OP min scale to 0 but let the max change as dictated by autoscaling. Another feature is setting a min autospan ie autoscale but do not decrease span to less than a value like 10% or 10 gpm.... using these settings helps take a lot of noise out of trends. . thanks for considering.
