281 VOTE
Status Completed
Categories Authoring Displays
Edit multiple objects at once
It would be nice to edit the colors, sizes, and how they are displayed in bulk all at one time. What I used to created in 1 minute in Coresight 2015 takes 10-15 minutes now.
  • Jordan Waits
    Dec 5, 2024
    Thanks!
  • PI User
    Dec 4, 2024
    Thank you very much for bringing this feature to the final product!
  • David Boswell
    Oct 24, 2024
    Since Processbook is being killed off, this is indeed a must to have for PIVision, otherwise it will take forever to change or create Process drawings for PIVision....
  • Guillermo Perez
    Apr 10, 2024
    This is really needed, i miss using the format paint brush tool in PI ProcessBook, it made changing trends and fonts in bulk a lot easier.
    We need something similar or better if possible.
  • Laurie Dieffenbach
    Feb 19, 2024
    One consideration for this request is that, when displays are migrated from PI ProcessBook, there may be symbols that are redrawn as composites (think of a valve drawn as triangles and lines that are grouped). You cannot set a multi-state on the group, so the symbol has be ungrouped and multistate settings applied to the individual pieces, which is not convenient (especially when you have 50 valves on a display).
  • Bethany McIlrath
    Oct 25, 2023
    Sometimes displays need to be resized to better display on different sized screens. Sometimes parts of a display are more important, so we want to enlarge those values while leaving others as is. It's very annoying that you can't drag to select multiple symbols and edit the format. Formatting each value individually is very tedious.
  • kimmyberly26
    Oct 25, 2023
    I love BradWilke's idea of a template solution but agreed, this would save alot of time. Especially when you are setting the same multi-states for multiple objects.
  • BradWilke
    Oct 25, 2023
    Seems like this would just be a band-aid solution for not having a templating type solution like most HMI's have. Create a widget and deploy to multiple displays, then have the ability to deploy changes to that widget to all instances in multiple displays as required.
  • Jürgen Schmidt
    Oct 25, 2023
    Our Use case is basically: We have an existing Display with similar objects like a dashboard with a lot of radial gauges that needs to be edited for whatsoever reason (show unit of measurement in all gauges, where it hasn't been shown in the past). By now we need to access the display option of every radial gauge manually and include the UoM. We would like to do this on bulk. Same for every other option like line strength, colour and others. And not only in between the same symbol but over different symbols sharing the same options as well: text strength should be changable if I selected a radial gauge, a value symbol and a lable together.
  • france Gabara
    Jul 26, 2023
    Any updates on this? we're migrating a massive amount of pages and this would help a lot!
    Absolutely cannot leave things like this. There is no way to size like multiple items except by 'eyeball'. A lasso feature would be welcome as well.
    Hear, hear. When working with a display with multiple symbols, it would be convenient to be able to change the format of all the symbols in one go. Many of the different symbols share the same format options, so no matter which symbols are selected, the format options in common should be configurable in one go.
    Customers are unable to select multiple text boxes at once and change/standardize their font color all together. They have to do it individually. There is an option to simultaneously change the font size but it would help if this could happen for font color too.
  • MPCPRO
  • Kastst
    It is tedious to change formatting one object at a time (and also error prone)
  • jsorrell
    It would be super helpful to be able to add a multi-state to multiple objects at once. It is very time consuming adding the same multi-state to fifteen different objects.
  • +182
1 MERGED
More configuration options with multiple Text symbols selected
Merged
Currently, when multiple Text symbols are selected, the only format option available in the Configure Symbol dialogue is Font Size. All other options should be available such as color options and rotation so that all selected symbols can be standa...
Brent Bregenzer almost 4 years ago in AVEVA™ PI Vision™ / Authoring Displays Completed
1 MERGED
More configuration options with multiple Value symbols selected
Merged
Currently, when multiple Value symbols are selected, the only format options available in the Configure Symbol dialogue are Font Size and Text Alignment (see image). All other options should be available such as color options, number format, and v...
1 MERGED
Edit symbol type settings in bulk, such as whether units are displayed
Merged
Currently to update PI tags to show their units in PI Vision page we need to update visibility settings of each and every PI tag one by one. Instead if there was a feature to update visibility settings of multiple tags at once in a PI vision displ...
YogithaSalian over 3 years ago in AVEVA™ PI Vision™ / Display Management / Displays Page Completed
