Created by Ivan Lozanov
Created on Jul 22, 2024
PI Adapter for OPC UA Discovery file attributes setting
At the moment the file generated consists 5 columns - nodeId,selected,name,streamId,dataFilterId.
Columns "name" and "dataFilterId" are always with value "NONE".
There is no option to set the attributes to include in the file.
  • Ivan Lozanov
    Aug 8, 2024
    Hello Jiyeon,
    I���m using this in order to get the Discovery:
    edgecmd get discoveries -cid PIR-PIOPCUA301 -id NodeIds-PIR-PIOPCUA301 -result -file C:\Adapter\NodeIds-PIR-PIOPCUA301.csv -csv -autoSelect false
    The file looks like this:
    [cid:image002.png@01DAE982.423E4B50]
    What to do in order to get a file without columns ���selected,name,streamId,dataFilterId��� ?
    First question ��� is it possible to
    Best regards,
    Ivan Lozanov
    Automation engineer
    Automation Department
    Phone.: +359 728 6 2453
    Mobile: +359 88 9631978
    Mail: i.lozanov@aurubis.com
    Aurubis Bulgaria AD
    Industrial zone
    BG - 2070 Pirdop
    Website: www.aurubis.com
    [cid:image001.png@01DAE981.641D0F50]
  • Ivan Lozanov
    Aug 6, 2024
    Hello Jiyeon,
    I have open a case ��� please see the attachment.
    The answer is that is not possible to set what attributes the Discovery will return.
    Best regards,
    Ivan Lozanov
    Automation engineer
    Aurubis Bulgaria AD
    Industrial zone
    BG - 2070 Pirdop
    [cid:image001.png@01DAE7FD.286523B0]
  • Ivan Lozanov
    Jul 31, 2024
    Hello Jiyeon,
    Please check the attached case.
    Is that right?
    Best regards,
    Ivan Lozanov
    Automation engineer
    Aurubis Bulgaria AD
    Industrial zone
    BG - 2070 Pirdop
    [cid:a3f15ba7-d039-4689-913b-83bad84bf4ca]
  • Ivan Lozanov
    Jul 25, 2024
    Hello Jiyeon,
    Do you mean change something int the file ���PIR-PIOPCUA301_Discoveries.json��� ?
    To add discoveries I am using this:
    edgecmd add discoveries -cid PIR-PIOPCUA301 -id NodeIds-PIR-PIOPCUA301 -query "RootNodeIds=ns=1;s=f|OS3_OS::List of all tags"
    To generate the file ���NodeIds-PIR-PIOPCUA301.csv��� I am using this:
    [cid:image003.png@01DADE76.64120260]
    Is it possible to remove columns ���selected,name,streamId,dataFilterId��� ?
    Is it possible to add other attribute column to this file?
    For example ���StatusCode���:
    [cid:image004.png@01DADE78.5150E9F0]
    [cid:image002.png@01DADE75.381E7130]
    Best regards,
    Ivan Lozanov
    Automation engineer
    Aurubis Bulgaria AD
    Industrial zone
    BG - 2070 Pirdop
    [cid:image001.png@01DADE73.5B1AA890]
  • Admin
    Jiyeon Hwang
    Jul 24, 2024
    Thank you for your feedback. If I've missed the nature of your feedback with what I've shared below, please do let me know in a follow-up comment.
    With the Discovery option, it will capture the information that is readily available in the OPC UA server. The "name" and "dataFilterId" properties are ones that you can specify (optional). If you would prefer to manually change this information before you push it into Data Selection configuration, you can add the following line to your Discovery request:
    "autoSelect" : false
    For example:
    "id" : "SampleId",
    "query" : "RootNodeIds=ns=1;s=MyDevice",
    Assuming you've installed the adapter on a Windows device, the exported configuration file can be found in your %programdata%/OSIsoft/Adapters/OpcUa/Configurations folder. You can open the json file and modify those parameters as you see fit. You can also use EdgeCmd Utility to export it as a .csv file to more easily update it using applications such as Excel. Once you've made the appropriate modifications, you can use EdgeCmd again to pull in the .csv file (or json file if you choose to stick to that format) into your Data Selection configuration. It looks like we do not provide an example of this in our documentation - I will work with our tech writers to update it with more details.
