165 VOTE
Attribute UOM Substitution Parameter
If you have a PI Point attribute with auto tag creation and you want the attribute UOM and PI Point engunits to match, you have to define it twice; once in the attribute UOM field and a second in the attribute configuration string, e.g. engunits=m3. If there was a substitution parameter for the attribute's UOM, you could use it in the attribute configuration string, e.g. engunits=%AttributeUOM%.
  • Alexandre Côté
    Jun 5, 2025
    Following up on this long due simple request... still messes up everything and its a critical component to have AF models built properly.
  • Martin.Thivierge
    Feb 13, 2023
    This feature is long overdue. This was identified as a critical piece of missing functionalities back with AF 2.1 in ~2010. I don't think this will be added/implemented in our lifetime. I surely hope it will.
  • Hachem
    Oct 11, 2022
    Hello, it would be nice to have the option to use substitution parameters for the UOM in the configuration string of attribute: like:
    \\%server%\%@.|tagname%;UOM=%@.|sourceUOM%
    we have Templates applied to difference Motors from different vendors, the UOM can change from one to another , these source UOM are saved in attributes ( using Tablelookup).
    this is really very important as now we need to do that in a custom script all the time.
    That's a nice one! Or when enabling the point creation in the template, pre-fill the units with the UOM of the attribute.
    In response to Roger Palmen, "That's a nice one! Or when enabling the ..." Hi Roger, I suggested the use of a substitution parameter for this because this is how AF pass the dynamic information during the tag creation process. So the idea was just to keep consistent with the existing mechanism. Thanks for your vote!
    It should be easier to create PI Points from the AFmodel using the UoM set for the attribute. This will help a lot to simplify that. When used for template attributes, the engunits could even be set by default to this, ensuring proper alignment
  • Asle Frantzen
    This is something we need. This is a pain today - we need to do it manually for all output points created from AF.
    I just ran into this again today using the Integrator for BA where i need to expose the UoM used for attributes...
  • DannyTaylor
    yes - this is a function we need to have please.
  • rfesler
    there are too many work around that are not stable. this would be a really really helpful feature.
  • ngardy_APP
    This function is really needed to improve PI AF...
    Fully agree with all comment below, for those seeking a workaround until development of the functionality : https://pisquare.osisoft.com/community/all-things-pi/af-library/blog/2016/04/08/create-pi-point-with-custom-uom-from-an-attribute-in-a-template?comment=14318
    As I user, I want to create my analysis output tags with the eng units matching the defaut UOM set for the element attribute. That would require the implementation of a substituition parameter like %UOM%.
  • Load older comments
  • +65
