Have the choice to delete ALL event frames at recalculation, even if not created by the analysis itself
although it's not clearly written in PSE, recalculation of an event frame generation analysis will ONLY delete the event frames created by this analysis. Event frames created manually in PSE or via an AF-SDK application are NOT deleted. Depending of the use case this can result in wrong information for the end users. Solving this by a manual deletion is very time consuming and quite impossible in case you have a lot of elements to handle. Please allow us to select (in PSE and AF-SDK) that all event frames must be deleted
    Can you confirm you have multiple applications creating event frames with the same event frame template over the same time period?
