The only way I have found to do this is to
Define all OUTPUT PI Point attributes with ReadOnly=False.
It would be nice if PI System Explorer would define this automatically when it is an output of an Analytic.
PSE does show when it is an output, so it should be possible.
Then dump all AF PI Point references into Excel.
Find just those attributes with the string ReadOnly.
Extract just the PI Point Name into a column.
Apply the Excel Conditional Formatting to highly duplicate values.
RE: The Data Archive doesn't keep track of the exact...
If you apply PI Point level security and allow the Analytics function read/write access to the PI tag, you can prevent two applications from writing to the same tag. e.g. PI Interfaces (or Manual Data Entry) and Analytics.
There are those situations where you want to schedule updating a PI Point using Event Based AND scheduled. You can't do it to the same attribute in the same element, but you can create two different attributes for the same PI Point.
