Status Completed
Created by Brian Deslatte
Analysis Management Plugin should ignore\ not allow backfill of non-history Analyses
Analysis Management Plugin should ignore\ not allow backfill of non-history Analyses.  This will improve manageability. In the management pane, one can select analyses and then  queue for backfill, even if the analyses have no PIPoint Data Reference attribute outputs.  This appears to take some processing.  The management plugin should ignore these or even unselect with messaging that these analyses are not eligible for backfilling. This comes up most often when users are doing a bulk backfill of analyses and do a select all of their analyses.
    Customer provided feedback related to this: If an analysis is not meant to be backfilled, it would be preferable that it is not reported as being “In Error”. For example, in the management tab, there may be dozens of analyses without output history that appear to be in error, despite not having anything wrong with them. If it’s not in error, then it would be better to not report it as in error
  • mjwakema
    This error shows up on analysis that only link AF attributes which cannot be backfilled. I should not receive a red exclamation point on the analysis for analyses I am not backfilling
