Product PI Integrators
Created by Guy Acciai
Created on Aug 16, 2022
Allow PI Integrator Installation without requiring HTTPS/SSL
Currently Pi4BA requires a SSL/HTTPS connection, and allows you to create an self-signed certificate. There is no option to modify this connection to HTTP or remove SSL, as Pi4BA doesn't use a standard IIS website, and none of the exposed configuration options allow switching between HTTP/HTTPS connections The self-signed cert approach causes client warnings about "not-secure" unless the certificated is locally installed on each client. While have SSL as a default option on the installation is fine, for internal projects connecting to internal servers, HTTP only (none SSL) should be provided as an installation option, to reduce the cost and complexity of maintaining a registered certificate.
  • Kenneth Barber
    Aug 16, 2022
    I disagree with this suggestion. Over time, you can expect security to be taken more and more seriously. Giving an option for HTTP only would be a step backwards, even if it is more convenient.
