1,020 VOTE
Status In development
Categories Manual Data Entry
Manually Enter Data for Attribute/Tag
Be able to manually enter data into an AF element attribute or a PI tag from a PI Vision display.
    May 14, 2026
    This item is in development for the upcoming PI Vision 2026 release.
    Please continue to share your needs and provide more detail by answering the following:
    1. What specific problem are you trying to solve with this enhancement?
    2. How would you like this feature to work?
    3. Who will benefit the most from this enhancement?
  • Sean-PFS
    Jul 21, 2026
    We are using Software Athlete Vision Library plus for manual data entry. We have ran into an issue where if we want end users to be able to delete time series data, we need to give them delete permission to the AF element since that is how it is referenced. In this solution, can you ensure we have the ability to delete data without needing to give delete permission to the AF Element. Context switching is why we are referencing AF and not the Pi Point directly.
  • pedrocosta
    May 15, 2026
    1- What specific problem are you trying to solve with this enhancement?
    First case is the process engineering team that collect some information from some equipment that doesnt have an electronical instrumentation installed, however they need to monitor these parameters, for example (some tank levels, material volumns, etc. Now they use to save the information in excel spreadsheets and is very difficult to extract the information and correlate with online pi data to do analysis.
    Second case: There are some parameteres that is used as input in some calculations on PI Analysis. These parameteres need to be updated periodically.
    2 - How would you like this feature to work?
    In two ways. Directly input by PI vision data by data individually and the capability to input a batch of the data.
    Operational teams (Process Engineering, Production Engineering and PCP)
  • Walter123
    Apr 23, 2026
    I have two use cases. First, we have maintenance personnel who make rounds collecting manual readings from various equipment that cannot be integrated into any SCADA or DCS, i.e. pressure gauges, bimetallic thermometers, etc. We want them to easily collect information into PI Vision via a mobile display, or standard display at the time of the walkaround. I also need users to be able to enter a worksheet or group of values and be able too set the time it was manually recorded.
    Second use case if for lab scientists to have a convenient way to enter data manually when working on a bioreactor. They monitor PI for continuous data but also enter values manually for offline samples. This would require they set the timestamp and value easily.
    Another use case is to allow users to enable or disable something like an alarm enable or hi/low limit. That should easily be possible through digital state set tags.
  • Brian Bolton
    Apr 23, 2026
    I work with a customer that is required to physically test materials and manually enter the results into the Historian. Having the ability to do this from a PI Vision display would be a tremendous time saver and allow the data to be seen in trends immediately. This will also help the decision makers to respond much faster to the data and make required adjustments.
  • photi24
    Apr 23, 2026
    Important for me is in this Topic also the possibility to setup write access for an speific attribute in one asset. in the moment all security settings in af are based on the elements. in our use cases it is needed, that an user can not access with writing all attributes of an asset.
  • Bradley Rinehart
    Apr 22, 2026
    We create an event frame when an issue is detected on production lines. We display the unacknowledged event frames on a PI Vision display. Currently the line supervisor selects a "Reason Code" from the list and acknowledges the event frame. We want the supervisor to be able to add comments related to the issue via the PI Vision display. The comments should be linked to the event frame.
  • Babe Bedenbaugh
    Feb 18, 2026
    1. What specific problem are you trying to solve with this enhancement? we need a way for the operators to communicate with our support teams when they do not meet their production objective for the hour and/or shift
    2. How would you like this feature to work? we would have a pi vision screen that will display their production results per hour and then beside the results we want to have a text box where operators can enter text comments about the issues they were having that drove the below target hour. we would also like the option of having a dropdown list so that we could trend issues
    3. Who will benefit the most from this enhancement? the whole operations team from the operators to our support teams to our leadership. it will make our issues visible to the whole team in real-time
    Jan 23, 2026
    • PI Vision currently cannot support governed manual data entry into AF Attributes or PI Points, forcing operators and engineers to rely on spreadsheets, offline notes, or ad‑hoc tools.
    • There is no standardized, validated, auditable way to capture manual readings, inspections, lab values, KPI inputs, or correction of data gaps directly inside PI Vision. The other AVEVA solutions, like the old PI Manual Logger or the AVEVA Mobile Operator, does not provide a quick implementation of straight-forward data entry form enriched with information that only PI Vision is capable to display.
    • Other options, like PI DataLink Data Entry Sheet , lacks in data validation, approval controls, error handling, timestamp rules, and audit trails, making compliance, traceability, and data quality difficult to enforce.
    • Provide a PI Vision custom Data Entry Symbol where users can:
      • Enter single values, multiple values, or time‑series tables for AF Attributes and PI Points.
      • Select targets via AF hierarchy browse, search, or pre‑configured lists.
      • Use single‑field input, checkbox/drop‑down for digital/boolean values, or tabular Excel‑like grids with timestamps.
      • Configure start/end time, frequency, auto‑generated timestamps, and optionally paste values from clipboard.
      • Benefit from full validation (data type, min/max, UOM, timestamp rules) before writing.
      • Perform writes with insert/replace behaviors and get clear feedback on partial failures.
      • Enable an optional approval workflow: draft → submit → approve/reject → post.
      • Use “Save/Cancel” pop‑ups, confirmation dialogs for overwrites, and clear inline error messaging.
      • Ensure all actions are audited (old/new values, user, timestamp, comments).
    • Operations teams:
      • Capture manual field readings, inspections, and real‑time operational observations directly in PI Vision.
      • Prevent data loss and reduce reliance on spreadsheets or handwritten notes.
    • Maintenance and Reliability teams:
      • Record condition checks, downtime timestamps, and machine status inputs needed for MTTR/MTBF and preventive maintenance workflows.
      • Manual Input of specific attribute values required for AF Analyses or external models
      • Improve accuracy and timeliness of equipment health reporting.
    • Engineers, Energy Managers, and Process Owners:
      • Enter KPI inputs, adjust calculations, correct historical gaps, and validate time‑series data with full governance.
    • Compliance, Safety, and Audit functions:
      • Benefit from structured audit trails, approval records, timestamp controls, and validation rules that improve regulatory reliability.
  • Prabhanshu Khare
    Jan 22, 2026
      1. Tracking KPIs Asking rate against Plan by enabling planners to put Targets directly using Pivision.
      2. Triggering an Analysis based on User inputs such as Check box, True or False kind of input. where specific input can not be automated due to technical constraints and rather it is based on Physical Inspections.
      3. Capturing Manually recorded data points
      1. Check Box or Drop down for Boolean data points at current time stamp
      2. Single Data field to input just one value at Current Time stamp
      3. Table with data field to input multiple values along with option to change time stamp, a Add row option would be great to customize number of tags
      4. All these inputs should have option to save changes, Popup to save or cancel will be great.
      5. Option to upload data from a csv file into PI DA
      1. Operations tedam can keep up the track of all the information including manual data capture
      2. Maintenace teams to know the satus of equipement under planned shutdown or breakdown and enabling teams to capture MTTR/MTBF etc accurately
      3. Compliance and governance for Safety checks, Preventive checks etc
  • Kushal_R
    Jan 22, 2026
    • We still have to use the PI Manual Logger admin 2014 version which is pretty outdated now. Thanks for considering this case.
    • Trending functions are limited on the PI Manual logger web, user have to use PI Vision for better trending functions anyways. So switching of web pages would be skipped.
    • A value update to an AF attribute value would help in the Analysis context (example a set point change) to trigger a calculation and the need to depend upon the tag to update the value with the help of PI manual logger would be mitigated.
    • There should be a way to add context like reason codes, comments or attach notes directly.
    • There should be an option to still have the limits.
    • The manual entry should be able to log Old value, New Value, User Identity, Timestamp, Source and Comment/Reason code.
    • For safety in some critical cases the value should be going in for a approval.
    • It should still work in a low bandwidth zone. Most of the times still people do not have a great internet connectivity on the site.
    • Bulk import and export data through files.
    • Data should be buffered as always.
    • Multistating should be allowed.
    • Context rich entry panel
    • Better security and governance.
    • Better auditing features
    • Validation Rules should be in place to avoid bad data.
    • Inline Functionality
    • Operators
    • Process and Production Engineers
    • Supervisors and Managers
  • Muhammad Umar Rashid
    Jan 22, 2026
    for example to enter weight of a roll or number of bales in a batching plant (value). Another example is to mention the reason of a machine breakdown (text).
    The value will be entered in an input box, which will be stored under the assigned PI tag. The time stamp and trending should be done by OSI PI as usual.
    operators
  • AGC_Koba
    Jan 22, 2026
      It will speed up analysis of phenomena in chemical plants. In chemical plants there are many datasets that we want to manage as time series in addition to the data in the DCS. Those data often cannot be collected automatically due to equipment design constraints, or automated collection is difficult from a cost–benefit perspective, so they are collected manually. If these data can be easily fed into PI, they can be readily compared with DCS values in PI Vision. As a result, we can start analyzing what is happening in the plant more quickly.
      There are two useful functions. The first is a way to record a single value to a tag together with its timestamp. The second is a way to record multiple values with multiple timestamps to multiple tags; for this case we envision a feature similar to uploading a CSV to PI Vision. In either case, I think a mechanism is needed to restrict which tags are allowed to accept such operations.
      The primary beneficiaries are manufacturing engineers and operators who perform phenomenon analysis.
  • Keetanat Siriwat
    Jan 21, 2026
    Feedback from a Refinery Operator’s perspective on Manual Data Entry & Trace Annotations
    1. What specific problem are you trying to solve?
    As a refinery operator, I face a 'Context Gap' every day. PI Vision tells me what is happening (e.g., a pressure spike), but I have no way to record why it happened directly on the trend. Currently, I have to write these events in a separate paper log or Excel. When the next shift comes in or when engineers look at the data later, they see the anomaly but don't know the cause (like a filter swap or a manual valve adjustment) unless they ask me. We need to bridge the gap between real-time data and operator knowledge.
    I need a simple, 'one-stop' interaction on the dashboard:
    • Direct Entry: I want to type lab results or setpoints directly into a value box on the screen and have it saved to the PI System immediately.
    • Trace Annotation: When I see a swing on the trend, I want to highlight that specific period and add a comment like 'Unit 01 Feed Pump Switch'.
    • Bulk Commenting: Often, one event (like a power dip) affects many traces. I should be able to apply one comment to all related traces in one click, so anyone looking at any of those tags later will see the same explanation.
    • Visual Markers: There should be a visual flag on the trend, so we know a comment exists. Hovering over it should show who wrote it and what happened.
    3. Who will benefit the most?
    Everyone from the control room to the office:
    • Operators: We save time, reduce double-entry, and have much smoother shift handovers.
    • Engineers & Managers: They won't have to call us to ask what happened two days ago; the 'digital diary' is already there on the trend.
    • The Company: We capture 'Tribal Knowledge' that usually disappears when an operator retires or changes shifts, making our Root Cause Analysis (RCA) much faster.
    This would transform PI Vision from just a display into a true decision-support tool for the frontline.
  • Joel Irvine
    Jan 21, 2026
    1. There are many variables the engineers want to manipulate. If they are PI tags, set up specifically for this function, then we can control permissions with AD groups and allow them to tweak things from Vision without going into AF where they can cause more havok. Being PI tags we can track the history of the changes. This also works for when the communications are down in the field, an onsite user can access a separate manually controlled display and enter in the readings from the site. Or used for manual rounds. It would not be used to edit PI tags that contain data streaming from the field, but new PI tags created specifically for manually entering data. Maybe pricing data, or ambient temperatures.
    2. Have a visualization within Vision that allows them to put in a value for the tag we specify, much like the trend window but with an entry box, have the ability to edit the time stamp as well by modifying the visualization.
    3. Engineers, admins, general users. Anyone that needs to make a change to a variable in the system, or an attribute.
    4. Also be able to edit the attribute value if it's not a PI tag, write back into AF for this. Same idea, changing a variable without trending it or entering whose on call for this location or any one of the hundreds of thousands of things people store in AF Attributes.
    We have our own in house developed visualization already for this, it works but it's basic and can't write back to an attribute in AF, just a PI Tag. We use AD groups and PI Identities to set who has access to modify these special MDE tags. We have to add the visualization back in when we do a Vision upgrade. Would be nice to have this out of the box functionality.
  • Dan.Louchbaum
    Jan 21, 2026
    Would be useful for adding comments. For example an hour-by-hour screen might show a Red hour based on KPI (actual vs target).. An operator should be able to explain why in a comment box next to the red hour... Therefor strings would be required as one of the datatypes. Some of our plants have implemented Custom symbols to make this work, but because that is not supported by our IT team or AVEVA we cannot recommend those as an approved path forward. Having it apart of PI Vision and supported would allow us to proceed forward with these kinds of dashboards in a global standardized solution.
  • Branko Radulovic
    Jan 13, 2026
    Lets make this out of the box function for PI Vision.
  • Tokiihro Hara
    Dec 2, 2025
    I share a similar concept.
    My proposal is to enable manual entry of attributes into the Event Frame.
    While the PI Vision Event Frame functionality already supports manual fields like Reason Code and Notes, allowing users to input standalone attributes would significantly broaden its applicability.
    @AVEVA
    We would appreciate your consideration.
  • Martin Bryant
    Jan 30, 2025
    I recognize why there is reluctance to change PI tag values from PI Vision - even given security. Could a reasonable compromise be found in setting PI attributes which do not have a data reference (static values)?
  • Nick Ciampa
    Dec 17, 2024
    @AVEVA, Any update since AUG 2022?
  • Nick Ciampa
    Dec 17, 2024
  • Load older comments
  • +920
1 MERGED
User input table
Merged
Scenario: I have machines that have manual gauges on them. Which means the only way to store the values is to manually read the gauges and store them in a document of sorts. Solution: I am wanting to store my data in Pi Vision. Basically, make a l...
Guest over 1 year ago in AVEVA™ PI Vision™ / Display Management / Displays Page 0 In development
2 MERGED
Custom symbol for entering AF values from PI Vision
Merged
Hi! It will be great to have a symbol for entering values from PI Vision to AF. Thanks!
Guest about 4 years ago in AVEVA™ PI Vision™ / Manual Data Entry 0 In development
