Status In development
Categories Ad Hoc Analysis
Move Trend Cursor with arrow keys (keyboard)
At the moment it is just possible to move a trend curser with the mouse. But hitting a certain point in a trend would be much easier by moving the trend course with the arrow keys of the keyboard.
    May 14, 2026
    This item is in development for the upcoming PI Vision 2026 release.
  • Kevin Elliott
    Apr 23, 2026
    1. By only being able to place the reference line along the time or x-axis by using the mouse, I am not able to specify a discrete value in time.
    2. I need the arrow option to allow me to move a mouse selected time reference line along the graph with a very fine degree of increment. As the arrow key is held down for a longer period of time the rate at which the time reference line moves along the x-axis can accelerate as long as once the arrow key is released the next time it is pressed the time variation increment will go back to a fine amount. This fine amount can be proportionate to the x-axis range shown on the graph with each instance. To help with the lag on data intensive graphs, all the data may not have to keep up with the changing time as long as the time readout displays each increment. This will allow selection of very specific data instances along the graph and then it will be possible to zero in on the exact peak or whatever feature that is desired to have data output on.
    3. Anyone who is trying to do detail data analysis will benefit from being able to select a more precise point in time to get a read on the variables of a particular graph.
  • Joshua Jenkins
    Jan 22, 2026
    The other comments are spot on. Having the ability to use the arrow keys for fine adjustment of the location of the vertical trend cursor was a valuable feature of PI ProcessBook that was not carried over to PI Vision. It would be helpful for our engineers to have this feature to move the trend cursor forward/back by a small increment using the arrow keys instead of needing to change the graph timeline to an extremely short increment of time. While adding this feature, it's also imperative to maintain the ability to drag the trend cursor using the mouse for more coarse adjustment.
  • Wahaj Syed
    Jan 21, 2026
    What specific problem are you trying to solve with this enhancement?
    When troubleshooting process issues, users often need to identify values at extremely precise timestamps sometimes down to a couple of seconds. Using only the mouse makes this difficult because the trend cursor tends to jump around, making fine adjustments frustrating and imprecise. This level of accuracy is critical in Operations, where even a small timestamp difference can reveal an important process change. This capability existed in ProcessBook and was heavily relied upon by Operations personnel.
    How would you like this feature to work?
    The feature should work the same way it did in ProcessBook. After placing a time cursor on a trend, the user should be able to move the cursor forward or backward using the keyboard arrow keys. Each arrow key press should shift the cursor by a defined increment (typically one second), allowing users to quickly and precisely land on the exact moment they need to evaluate.
    Who will benefit the most from this enhancement?
    Operations staff, process engineers, production teams, and anyone involved in daily troubleshooting or analysis of time-series data will benefit. These users frequently need precise time alignment to identify peaks, dips, step changes, or anomalies. Keyboard-driven cursor movement significantly improves accuracy, reduces frustration, and restores a capability many relied on in ProcessBook before transitioning to PI Vision.
  • Bethany McIlrath
    Jan 21, 2026
    When troubleshooting process issues, being able to use the keyboard allows you to identify values at a precise time. Sometimes the difference in a value within a couple seconds can be really important. When clicking with a mouse, you can't get that precision, and it often jumps around. This was an extremely useful feature of Processbook for Operations personnel. The feature should work as it did in process book. Once you click a timeline onto the trend, the keyboard arrow keys would then allow you to move the line back and forth by a second to get to precisely the time you're looking for.
  • Claudio Coutinho
    Apr 15, 2025
    We really need to use this functionality with the arrows to obtain better precision in selecting the period of the measurement graphs.We request that it be implemented in future versions of the software.
  • Bethany McIlrath
    Oct 25, 2023
    I have run into this issue multiple times since switching from Processbook to Vision. It's very frustrating to try to drag a cursor to the precise point on a trend.
  • MaxWör
    May 15, 2023
    Especially when switching from ProcessBook, the users are used to this function and miss it very much
  • Jason Price
    Jan 12, 2023
    this would be very helpful with our daily ethanol productions
  • Mario_B
    This would hep to be more accurate when trying to identify peaks and low points as well.
7 MERGED
Trend: Allow keyboard arrow keys to move a cursor in the trend
Merged
As it was possible in Processbook, allow the possibility to use arrow keys (left/right) to move a cursor in the trend.
francis hennard over 1 year ago in AVEVA™ PI Vision™ / Symbols In development
1 MERGED
Cursor doesnt move when i click left or right arrows!
Merged
In pi processbook it was possible to move the cursor by pressing left or right keyboard keys, but why is it not moving in pi vision?
Guest over 2 years ago in AVEVA™ PI Vision™ / Display Management / Displays Page In development
6 MERGED
Possibility to move vertical cursor with left and right keyboard keys on trend symbol
Merged
This feature is available in PI processbook . by selecting the vertical cursor to move if several are positioned on the trend
jerome.boudon almost 3 years ago in AVEVA™ PI Vision™ / Symbols In development
