114 VOTE
Status In development
Categories Ad Hoc Analysis
Created by Ryan McErlean
Trend: Statistics between cursors
When adding multiple cursors to a trend, have a way to show the statistics (delta/min/max/avg/duration) between the two cursors so that a user can easily understand what happens during the cursor times.
    May 14, 2026
    This item is in development for the upcoming PI Vision 2026 release.
    Please continue to share your needs and provide more detail by answering the following:
    1. What specific problem are you trying to solve with this enhancement?
    2. How would you like this feature to work?
    3. Who will benefit the most from this enhancement?
  • Chris Mitschelen
    Oct 12, 2025
    This may have already been identified in this thread but a rate of change between two cursors would be very useful as well, ie, for a temperature trend I want to mark point 1 and point 2 and have a display of degrees F/minute.
  • kazimmohammed
    Feb 4, 2025
    When analysing trends, there can be times to compare or summarise the period between them, as in investigating process upsets or optimization opportunities.
    There should be a way to select the cursors, and the associated stats show in a tabular format e.g. under the trend's x axis label.
    Process engineers, operators and I&C (Instrumentation and Controls) engineers are those who stand to benefit the most, as users.
  • Athanasios Kitsios
    Feb 4, 2025
    The Deltas could have also percentage change in brackets: (+/-%) with Green colour for positive and Red for negative change (or other colour-blindness equivalent set of colours)
    Oct 24, 2024
    This feature was in Wonderware ActiveFactory Trends. We recently migrated to PI & are using PI Vision, it sure would be nice to see the feature brought over as Aveva owns both PI and Wonderware.
  • Dan.Louchbaum
    Delta in value and delta in time between the exact cursor locations too!
    Delta in value and delta in time between the exact cursor locations--> Good idea!!!
  • RandyHawley
    Also to use the two cursors as the start and end times of zooming in.
  • +14
