259 VOTE
Status Evaluating
Created on Aug 18, 2022
Display Versioning
Need to have ability to version PI Vision displays Need to be able to revert back to earlier versions of a PI Vision display.
    Feb 3, 2026
    We are evaluating this feature request towards a future PI Vision release. To help us understand your needs, please provide more detail by answering the following:
    1. What specific problem are you trying to solve with this enhancement?
    2. How would you like this feature to work?
    3. Who will benefit the most from this enhancement?
  • hooper
    Jan 23, 2025
    Both PHMSA and NERC require revision control of content presented to Gas Controllers and System Ops staff. Plus it is just a good practice; revision control is used widely in enterprise level operations. Similar to ISO-9000x requiring document version control. We need to be able to show, in an audit, when a display changed, who did it, why (authorization) and be able to revert to a previous version. And at any time we may need to revert to a previous version if a change was made that broke something.
    As mentioned by others, this was easy with ProcessBook as the PDI files could be checked into a revision control system. We used SourceSafe, then SVN and also AzDO. The ability to revision control PI screens 'went away' after migrating to Vision.
    In order to continue using PI Vision screens in our operations centers, we are currently still using (and revision controlling) PB files, using your converter to convert them to Vision. I'm sure that 'work-around' will not persist long term. When it quits working, we'll be looking for another tool; that will be a heavy and expensive lift, but a mandated one.
    1. The problem we want to solve: Keep the ability to use PI Vision in areas where revision control is mandated.
    2. How should it work? Like mainstream revision control systems. Revision by file/display. I like the integration of SVN & GIT into Windows Explorer using Tortiose. It would also be nice to have an object/tag we could place in AF and display on the screen showing the revision number & date/time.
    3. Who will benifit: All users of Vision screens in our Gas Control, Distribution Dispatch and System Operations. They will get to continue to use something familiar. And support staff won't have to find and deploy a different solution.
  • Kelsey Bobeck
    Jan 10, 2025
    I think this would go really well in tandem with release notes. For example, a pop-up that would come up the first time a user visits the new version that could state what’s changed.
  • jt.wilcox@ipaper.com
    Jan 9, 2025
    1. Coming from a long time processbook environment, the idea of being able to restore a display is a pretty common expectation. People will put out changes and for one reason or another want to be able to restore the original. I guess you could have a process make version copies of displays before making changes, but that would seem to just clutter up the system.
    2. Ideally this could be initiated from the client by the end users. They could see a list of versions for a given display and pick the version they want to roll back to.
    3. I think mostly the end user, but given the current state the system admin and support will also benefit.
  • Martin Bryant
    Jan 9, 2025
    I had previously suggested this idea at this location:
    https://pisystem.feedback.aveva.com/ideas/PIVISION-I-1751
    it got a handful of votes
    Allow PI Vision administrators to mark selected displays as "Version Controlled" and keep revisions.. With the ability to revert to prior versions. This would also track the editor of each version. I don't think this should be a default or user option - but rather a flag that only PI Vision administrators can apply to displays that revisions should be tracked for.
  • Rick Smith Jr
    Jan 9, 2025
    I echo the comments below... The only thing I would add is a limit on the number of versions kept to prevent overloading the database. The limit could be the number of versions and/or the number of days old a version is.
  • jerome.boudon
    Dec 17, 2024
    All our comments are already explained in the existing comments. Nothing more to add
  • twillis
    Dec 10, 2024
    Enabling a rollback to a previous version would be very useful. There have been many of times a change to a graphic and the idea ends up being too cumbersome and being able to start from scratch would be helpful. Also, keeping a few versions would be great to enable check and balance from old to new version.
  • Thomas Lee
    Dec 9, 2024
    With a web-based design there is a much higher chance of production changes that can be made in error that can't be recovered or that with it being possible to have multiple users overwrite each others changes. Before with a file based system it was no problem to restore working versions from backups so the last of versioning or an automated backup system in Vision is a step backwards.
  • FMalet
    Dec 9, 2024
    To help you, this is our vision :
    • Specific problem :
      • when users are saving a Display by mistake or with an error that cannot be easily modified once saved
      • identified who made a modification when several users can work on the display
    • How
      • Same as for O365 document where it is possible to view all modificatons carried out, when and by whom,
      • With the possibility to view the old version, restore the old version or remove the old version
      • Possibility to define how long each version can be stored and/or how many (to be configured by PI Vision Admin)
    • Who will benefit :
      • Users (less stress regarding modification)
      • PI Vision Administrators to help users
  • gbbiv
    Dec 6, 2024
    Quick and easy backup and restore is so essential to a system like this that we developed our own solution in house. If we hadn't we'd probably have to purchase the system that Werusys is developing to accomplish the same thing.
  • ValterFostini
    Dec 5, 2024
    agree with Versioning, Major/Minor and the possibility to define specific users groups that can access both the published and newly versioned version.
    every change should be trackable in terms of a little changelog.
    not sure if an internal tool for finding the differences will do the expected job..
    "performances" data should be collected separately for each version in order to optimize the new changes.
  • Brian Murphy
    Dec 5, 2024
    Agree with all below. Having ability to publish a Major Version (V1.0) of a display while also having the ability to edit a minor version (V1.1) in the background. Once V1.1 is tested and approved then the new screen would be published at a new major version V2.0 for example.
    In a GMP environment we make software changes under a Quality Management System (QMS) or a change management process. Each version should be attributable to a change.
    For example:
    V2.0 Updated to include 2 x Temperature elements under QMS-123456
  • Maxime Raguenet
    Dec 5, 2024
    Agree 100%, comments below describe my vision of this functionnality just right.
  • Joe Staublin
    Apr 18, 2024
    I believe there is a display version number already. I wrote a PI-Vision display backup based on a OSIsoft example script. Part of the metadata had a count that changed every time the display was updated. I used this to keep the previous versions. Not perfect, because it's just a point-in-time backup of saved displays.
  • FranzK
    Aug 18, 2022
    it should be possible to get also the information what changed from version to version (e.g. symbol ... added to the display, symbol ... color changed from red to green). or at least it should be possible to enter this information manual.
    Aug 18, 2022
    This should also include the ability to effectively manage version releases. If I publish a display for all the techs in my fleet to use, I still need to be able to tweak it in the background. I need to be able to break it, fix it, develop new capabilities and analysis, THEN republish the new, validated, and tested/approved version. All while leaving the live version intact.
    Aug 18, 2022
    - Restore document to specific version - See at a high level what changed between versions (symbol add/delete, asset edits, location move)
  • jdjohnstn
    Aug 18, 2022
    I'm not sure if this is included elsewhere, but version should live past display deletion. If I delete a display by accident, I should be able to restore the display to visibility, beyond having to restore the entire PIVision SQL server database to a new database, and moving the display back.
  • Pete Long
    Aug 18, 2022
    (The new levels of 'importance' are nice for assessing how much desire there is for the item voted on, but why "Not at all"? If it really was "Not at all" important, i wouldn't have voted for it. How about, "Nice to have", or, "Make me smile", etc.?
  • +160
